Originally Posted by eph
thank you sir! i will check it out today, i called a machine shop for help and they basicaly wanted to charge me for the info lol, i managed to get the torque specs from him (96 incn pounds so 8 foot pounds on bearing caps). since the pounds are so low i dont thin  k ill bother with the torques sequence
There's a reason to do it the right way, so follow the procedure from the factory. You miss a step on a lightweight engine like that and you'll be doing the job again.
Don't half *** it, go it right.
