Old 04-11-2012, 07:54 PM   #11 (permalink)
aerohead
170
Originally Posted by gotmehooked View Post
well went for my first drive with the block on, and going up hills the truck seemed like it lacked power. tranny temp was also climbing to 170 degrees. Pulled over removed the block for the rest of the ride, and temp steadied around 145 degrees. Any suggestions? Would cutting some slits in it still provide an aerodynamic advantage or is a truck to big to have critical airflow blocked.
170-degrees is a good temp for the tranny.You might record your ambient temps on the days you test and build up a database for your rig.
Racers try to pre-warm all their lubes before the race to get everything to equilibrium temp and minimum viscosity to extend their range between pit stops.
