There's also finding a known distance, and traversing it over a given amount of time. Miles traveled / time taken == MPH (or km/h if you're using metric units). You can use that to calibrate your actual speed against the speedometer if you can manage to keep a steady speed for a known distance.
A longer distance (and time) will generally mean less error in your measurement this way, as well.
-soD
