Hi all, Finally had time and got busy! First off, Air'd up my tires to 43Psi Factory(Kumho) 195/60/15 on steel rims. Stock Hub caps will soon be changed once i get my butt in gear again. too many projects right now.
Front(flush as can get) lower Grill Blocker, made from Coroplast and taped on with wide Paper tape(works well for me, clear tape would be a nightmare to get off!
The Rear Wheel Skirts have about 3/4" -1" of space free from the wheels, and fit nice and tight with the body line and flow!
Pretty happy with how it looks and performs haven't had one issue so far, but will be placing more permanent materials later. I'm not a huge number crunching guy unless it relates to speaker building. But I may try to run some numbers later... Just doing a basic tank drain/Fill up then calculate the MPGs. I've changed my driving habits a little bit, but i still mostly go the limits or near them, I've been coasting more and I'm already nice to the "GO" and "Oh Sh$%" pedals enough
By this time, Ive got 205mi on the trip meter, with I'd guess around a gallon or so more than 1/2 tank an improvement already!
