Originally Posted by mans
guys i'm guessing this setup would provide 330ah and 12v . correct?
Yes... other then the DC to DC converter is only 90% efficient so 297 ah or 289ah if it's 13.7v... with lead acid batteries it's always better to have a larger pack size so it's shallower depth of discharge as 50% is as far as you want to go if you want them to last 5 years, if you drain down to 20% full then 2-3 years is about what you will get.
