"Blueprints can be way off"? It's pretty easy to judge the good ones vs. bad ones.
But I agree with what you're saying about the template. Since the wagon's roof is so flat you can probably stretch the rules a little to put the 0% mark near to the rear of the roof. It will give a better overall flow than pretending you can cut off a chunk of the rear to fit the template.
