Those guys who reviewed the Zuma 50cc 4-stokers out in San Francisco had GPS units mounted on the handle bars.
I've used my GPS nav units to calibrate my SG2 in different cars.
It really helps to know if your factory odometer and MPH display is off a bit.
I've heard that some scooters readings are way off on MPH. Fast and slow.
Anyways, you might try making a
test road-trip with a GPS recording your miles, starting right after you get a fill-up (on a flat surface).
And ending back at the same pump..
So, now that the weather is getting a bit warmer, how much fun are you having on that new scooter??
