Thread: VX wrong trans
Old 04-12-2012, 09:53 PM   #25 (permalink)
SiVX
EcoModdingRealist
SiVX's Avatar
The Blue Lagoon - '92 Honda Civic VX
Ok guys, I have some questions concerning transmission swaps in VXs... First off, other than RPM testing, is there any way to visually identify that I have a VX tranny?
Originally Posted by Joe1234 View Post
I drive a VX and it is 2000RPM in 5th gear at 70MPH. Sounds like the shop you used is full of retards as usual. They either thought you'd be too stupid to notice or they were too stupid to pay attention to detail.
The reason I ask is above. I hear all different opinions on where the tach should be at Xmph... I just bought a VX that has HX rims with 185 tires. At 70mph I am above 2000RPM... And with bigger tires I should be slightly below, correct?
"check the engine rpm at 100 km h it should be 1900 rpm in fifth gear
if rpm is 2400 you got a tranny from civic 96-2000 hb
if rpm is 2700 you got a dx 92-95
if rpm is 2900 you got a si tranny"
Read that on another thread. I'll use my GPS unit to verify accurate speed and see what I get at 60 and 70 mph...
Question:" My 185 tires are 10.8% larger than the VX 165s. Does this mean my RPMs for a given speed should be about 11% lower than normal?
Thanks for the help.
[ACHV ALL]
