Old 04-13-2012, 06:03 PM   #6 (permalink)
aerohead
foam rope caulk backer
At hardware stores and home improvement stores,in the weatherstrip section,you'll find foam rubber rope which is designed to go into large cracks as a backer for caulk,made of material, quite like pipe insulation.It comes in a roll in a couple different diameters,is that same dark gray color and you may be able to just push it into the gaps.
