Old 04-13-2012, 09:45 PM   #11 (permalink)
user removed
If you are going to block off that much then you absolutely need to monitor coolant temps.
I also agree with you about coasting in neutral. My 2011 Fiesta was totalled and repaired as a salvage vehicle. This means no warranty of any kind, not even recalls are honored by Ford.
I am just beginning to try coasting in neutral and it seems to work fine, with the car going to 6th gear then engaging the clutch without any trauma.
regards
mech
RiderofBikes (04-14-2012)
