Old 04-14-2012, 12:20 AM   #13 (permalink)
iveyjh
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
I have a 2000 Chevy Metro 1.0 3cyl. I use an Apexi Safc air fuel mixture adjuster that works with the map & TPS sensors. Google Safc/Vafc, I find mine on ebay or craigs list.
I get anywhere from 50 to 62 mpg according to how I drive. I get 52mpg at 60-65mph have got over 70 mpg on shorter legs.
You can adjust fuel ratio lean for only low load under 3000rpm or any range that you want.
I have been running this on 3 of my cars for 10 months, 2000 metro, 1998 hx 51-62mpg, 2002 Acura RSX 34-38 mpg. If you set it lean on low load it will not hurt the engine. It actually runs cooler.
The Following 2 Users Say Thank You to iveyjh For This Useful Post:
California98Civic (04-14-2012), cycleguy (04-14-2012)
