Old 04-14-2012, 07:08 PM   #9 (permalink)
Mr. Previa
ECOModder
Mr. Previa's Avatar
RAV - '13 Toyota RAV4 XLE AWD
90 day: 27.56 mpg (US)
4-14-2012 Solar v2
I relocated the solar panel and controller. The output of the panel inside the car just wasn't cutting it. I decided to mount the panel on the hood for a few reasons.
* Easy mounting
* If I messed up the mounting points, I could easily repair them.
* I am HOPING that this will cause a lesser negative effect on aerodynamics.
I need to find or build a hood deflector. Time will tell how badly this will effect (if any) my fuel economy.
I just drilled 4 holes to mount the panel to the hood. I decided to go ahead and sand and rolled bed liner on the hood because the clear coat was peeling bad. It looks, well, umm, interesting. :
I mounted the controller on the driver side, under the dash.
3585 pounds of twisted steel.
Recreational | Active | Vehicle | 4x4
...scratch that... AWD
