Old 04-15-2012, 09:21 AM   #27 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Originally Posted by RiderofBikes View Post
Yes Yes,
?Manually operated flaps, like the flaps of air vents in your car/household for Heat and A/c? ...Eventually wired to the inside, for ease of use.
(open for traffic/low speeds, closed for highway stretches, or anywhere in between)
I used a lever controlled cable (McMaster part# 2461K21) mounted on the side of the center tunnel to adjust my grill block, but a gear selector control cable from an old 10 speed bike would work just as well.
Closed for the first 10 or so miles following a cold start, closed for most winter driving, open for most summer driving after the engine has warmed up, amount of opening depending on outside air temps, engine load, and airspeed.
aerocivic.com
The Following 2 Users Say Thank You to basjoos For This Useful Post:
RiderofBikes (04-15-2012), WD40 (04-15-2012)
