Old 04-15-2012, 01:44 PM   #22 (permalink)
drmiller100
Originally Posted by APU View Post
During high torque demand, accelerating tow vehicle, uphill and passing, the auxiliary engine would run providing boost to the engine. My target is 6 psi, this should provide approximately 33% more torque. The auxiliary engine would be shut down during highway cruise and only restarted when required. The majority of the time the main engine would be run naturally aspirated. Would running the auxiliary engine during cruise, with taller overall gearing lowering rpm, increase or decrease the main engines fuel consumption ?
pumping air for the fun of it will decrease mpg.
what size main engine and what RPM are you thinking, and I can run the numbers for you as to how much horsepower it will take.
The Following User Says Thank You to drmiller100 For This Useful Post:
APU (04-15-2012)
