if LED requires more current then Arduino +3.3V pin could provide - other +3.3V voltage regulator should be used.
Resistors could be similar - just output voltage should be between 3V-3.3V
If you have any other 5V->3.3V divider/converter - it could be used inplace of all resistors.
