Old 04-16-2012, 03:21 PM   #795 (permalink)
eimix
This one has its own voltage level converter.
And adafruit gives circuit for connecting it. you should follow it.
And it is with SD card support, so if you are going to use LCD only - not all pins are needed to connect (Card_cs and MISO).
And to my previous drawing
SCK = SCL
MOSI = SDA
TFT_CS = CS
D/C = RS
RESET = RESET
VCC = 5V
LITE = led power, but not sure.
The Following User Says Thank You to eimix For This Useful Post:
Keeper (04-20-2012)
