Old 04-16-2012, 05:25 PM   #7 (permalink)
oil pan 4
For a gasoline engine you can always try file fitted rings or zero gap rings.
The higher compression is a good idea.
Try to stay close to .002 inches of clearance on the rod and main bearings that way you might be able to run thinner oil.
Go with the newest generation of injectors that can be made to fit your car.
Check the wiki.
