Thread: Cm400 help
Old 04-17-2012, 11:22 AM   #3 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
Concur with the problem being the idle mixture needle. The SeaFoam mixture is pretty strong also, which could exacerbate the problem. Check to see that there are no vacuum leaks, ensure the seals between the carbs and head is clean and tight.
Good design is simple. Getting there isn't.
