Old 06-01-2008, 04:10 AM   #2 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
getnpsi -
You can get a "normally open" switch and attach it to a relay that you connect to be "normally closed". You attach the button so that when the button is closed, it forces the relay to go open. Not as elegant, but works like a charm and can take the worry out of switches not being able to "take the amps".
Otherwise, if you look on Marine supplies websites that specialize in 12 Volt electronics, you can (eventually) find these switches.
Good electronic switch site :
Switches - The Electronics Club
http://www.kpsec.freeuk.com/components/switch.htm
EDIT: Ha ha, found this 35MM diameter monster :
Momentary mushroom head emergency stop
http://www.rapidonline.com/Electrica...4/kw/momentary
CarloSW2
American Solar Energy Society
