Old 04-17-2012, 12:55 PM   #20 (permalink)
bobo333
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
started the block today
first the old indicator holes, cardboard and clear packing tape:
then the upper grill, same again:
then i started on the outside of the lower grill and used the clear packing tape to cover the fog lights but still let the light come though:
from a distance you can hardly tell the lower block is there:
i also bent the number plate a bit so it molds to the body better and taped around it as well, look pretty smooth from the side now:
i ran out of tape so il finish the rest tommorow probably...
also heres the build thread which will follow all of my mods: http://ecomodder.com/forum/showthrea...y-21218-2.html
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
The Following User Says Thank You to bobo333 For This Useful Post:
aerohead (04-17-2012)
