mpguino install
Well excited got my mpguino in and blah reading are off bad. I have a 92 accord sedan with the pt6 ecu manual shift.
Im getting reading on it but the rpm/speed is way off and the mpg coming off of it are reading at 00.90 something, never goes over 1.0 and rpm is off by about 500. Im guessing the vss and injector wires i installed wrong or something since there all off. Idk what do you guys think, dont wanna get a new tank of gas till I have this figured out.
From what I read from others the orange wire at the ecu is the vss wire to tap into (maybe ill solder the actual wire to it, right now its spread and wire thru the hole). Brown wire on a1 is my injector lead. Any assistance guys be much appreciated.
