Old 04-17-2012, 04:34 PM   #8 (permalink)
chrisoverson
The Mad Technician
Rover - '98 Rover 218 iS
Originally Posted by California98Civic View Post
When you say 3/4 throttle do you mean throttle position? Because I usually need only somewhere in the 20s% throttle ... the goal is "3/4" or more properly somewhere around 75% load (not the same as throttle). What instrumentation are you using?
Yes I meant a throttle position of 3/4, as in the pedal three quarters of the way to the floor. Is this not right?
I'm not using anything except the fuel usage monitor I've made with an arduino. I want to fit a vacuum gauge but haven't yet, is that what I need?
