crx warm air intake
my carbureted crx has a 1 3/8" hose going to the exhaust manifold . it is vacuum operated to open when the engine is cold. I am considering fixing it where it is open all the time. the problem is, it raises a flap that closes off the main air tube, which is 2" diameter. I could remove the flap , allowing it to get air from both sources, or partially block the 2" tube, allowing it to draw air from both. any suggestions?
