Old 06-01-2008, 07:33 AM   #47 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by Greenblazer View Post
Let me simplify and ask again, is it, or is it not safe to run tires at MAX sidewall PSI in your educated opinion? A simple less technical answer would be appreciated.
I tend not to use terms such as "safe" and "unsafe" - too "black and white". I prefer to use terms such as "risk", which to me is a bit more accurate and descriptive.
So let me answer your question this way: Using up to 5 psi more than the vehicle placard pressure (assuming the same size as listed on the placard) is likely a small increase in risk. The footprint size and shape isn't much different and the tire's spring rate is only up at most 15%, so I don't think the handling will behave much differently (other than be a little more responsive). The impact risk is higher, but again this is less than a 15% increase in stiffness, and the risk of an impact event is fairly low to begin with, so while the liklihood of a failure from the event is somewhat larger, the overall risk is still fairly low.
Using up to the max pressure on the sidewall is a little more risk, but I've explored some of the handling issues when I raced. The only issue I feel uncomfortable about is the impact situation, but, as I explained in the paragraph above, the increase in risk of a failure is mitigated somewhat by the overall liklihood of the event in the first place. The problem here would be that sometimes tire impact failures lead to fatal accidents.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
