Old 04-17-2012, 09:10 PM   #23 (permalink)
JellyBeanDriver
JellyBeanDriver's Avatar
I see now why you were asking for a +5V supply.
I don't recommend adding the fan. All you'd end up doing is adding more heat to the unit via regulator power dissipation. High heat on the LCD display itself may cause the image to darken, but it is reversible and true for all LCD's in the hot sun.
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
