Old 04-17-2012, 09:43 PM   #3 (permalink)
drmiller100
cetane is the opposite of octane. Higher cetane means the fuel burns faster.
He could get the same results by advancing his ignition timing. if he is seeing that much change, then his engine is messed up somehow.
to get the same, run the lowest octane gasoline you can find.
