Old 04-17-2012, 09:56 PM   #33 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by drmiller100 View Post
those are precombustion chamber engines, and run with incredibly inefficient parameters.
Exactly. That was the best technology they had, when super fine spray patterns and high injection pressures were not yet possible because of lack of machining tolerances and "pre-cups" were the only way to make it work. Injection pressure was probably peaking at 4000 psi at rated HP, where even an older TDI (rotary pump) will hit 15000.
Originally Posted by hawk2100n View Post
But the best way to drive these cars for max fuel economy is below the onset of boost when possible, which is hard.
This is because when boost isn't there, the air/fuel control in the fuel pump limits rack travel, AKA fuel quantity per stroke. Electronic engines do a variation of the same by limiting mm3 per stroke until boost reaches a certain level (smoke limiting) and EGR flow reaches a certain level (NOx limiting).
