Thread: Hello all!
Old 04-17-2012, 11:17 PM   #3 (permalink)
larrybuck
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Welcome! Have you tried bumping up your tire psi.? A partial grille block might be easy to do. Build yourself a front airdam. Can you omit a passenger mirror, and may be downsize the drivers side one?
Plenty of info here. Read the 65, and 100 tips.
If your accel. pedal linkage is fairly soft, consider driving in your socks w a very small
pillow under your right heel FOR those long weekend drives.
The sensitivity will help you to drive smoother!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
