Old 04-18-2012, 01:33 AM   #25 (permalink)
vacationtime247
vacationtime247's Avatar
The Toylet - '87 Toyota Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 TMEC Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Ford Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 47.52 mpg (US)
Ass Tick - '01 Pontiac Pontiac Aztek GT 5 Door
Green Baby Poop Stain - '01 Pontiac Aztek Aztek Base Model
Black Track - '01 Pontiac Aztek GT
Torched out the motor mounts. Drilled out holes above the stock ones, then used a dremel to notch up the areas where it will bolt to. The engine wants to sit higher than where the stock mounts are. So, raise the mount bolt location. Next step is to get bolts for the motor mounts and big washers for the back side under the crossmember. Yet another project, it will be completed eventually, one step at a time.
VT247
