Old 04-18-2012, 06:56 AM   #81 (permalink)
IamIan
IamIan's Avatar
Originally Posted by jtbo View Post
at steady speed 26% efficiency put into calculator is giving correct results.
Well at least that is a starting comparison point.
I suspect that is not the peak efficiency point ... on a BSFC chart ~26% works out to around ~300 g / kwh ... There are many ICE's including Gasoline ICEs that do significantly better than that ... so While that might be a fair estimation of one point on the BSFC ... I do suspect it is not the peak efficiency point.
