Thread: Hello all!
Old 04-18-2012, 08:22 AM   #4 (permalink)
lateralus819
Originally Posted by larrybuck View Post
Welcome! Have you tried bumping up your tire psi.? A partial grille block might be easy to do. Build yourself a front airdam. Can you omit a passenger mirror, and may be downsize the drivers side one?
Plenty of info here. Read the 65, and 100 tips.
If your accel. pedal linkage is fairly soft, consider driving in your socks w a very small
pillow under your right heel FOR those long weekend drives.
The sensitivity will help you to drive smoother!
My car is fairly new, rather not remove parts just yet. Tires are at sidewall max of 49psi. The 40mpgs was achieved at 35 psi so well see. What does a grill block/air dam do? Also, i think ive mastered my foot pedal i can guess fairly accurately what my mpg meter is reading. Thanks.
