thanks guys,
its actually a 1.3L 4 cylinder, and i live pretty much on sea level, most of my driving would be under 1000ft id say
so i should accelerate at 1-2in then coat as close to 20 (idle) as i can? where should i be shifting gears? the last tank i shifted around 2000rpm but the vacuum guage shows the vacuum increasing at around 3000 with a constant throttle level, is this where i should be changing gears to get it back up to 1-2in until im at the speed i want to be at?
