Old 04-19-2012, 09:26 AM   #24 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
You can rule out the ignition-on-in-gear "glide" option. It's not anything close to a glide. You're better off just running steady speed than trying an in-gear p&g routine. For a glide to be worthwhile, you need to be freewheeling and minimizing drag.
* depends on how the car handles no-throttle. Some automatics will freewheel which is good and makes for easy p&g - just let off the gas. Some hold in gear and engine brake which takes away the value of p&g unless you manually go to neutral.
