Old 04-19-2012, 11:01 AM   #20 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Originally Posted by landsailor View Post
fan motor resistor. three wire wound resistors. 2 may be burned out(not uncommon) and only the lowest speed resistor is working.
It doesn't work that way. If the resistor only has its lowest speed setting available, then selecting a higher speed setting will leave you with no fan at all until you dial the knob back to the lowest setting.
Transmission type Efficiency
