I am nearly done drafting the 2" thick sections -- I am on #40 on the rear; having done the 38 section in the front. I have just 12 sections left to go!
Then I'll know an exact count for the number of sheets of foam I need to order (looks like it will be about ninety two 1" thick sheets of Dow XPS), and then I can get going on cutting them. That still means there is a fair bit of computer work -- the sheet layouts have to go back into SketchUp and and edited to then generate the g-code for each.
