Do you know what the extra weight is?
The difference between extra weight - 2 bags and an umbrella & a trunk loaded with concrete blocks is significantly different. See if you can calculate the extra weight and I am sure one of the gurus here will give you a better answer.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
