Old 04-20-2012, 08:00 PM   #20 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by ecomodded View Post
If you feel I missed something from the paper that you feel is important please post up with it. I am not not trying to learn from the paper it just seems to be data of another direction, aircraft to be exact.
Figure 14 has data in it to where atmospheric pressure is held at sea level and air inlet temperature is varied along with the quantity of fuel injected. If you look at the bottom of that figure you will find that they give chart fuel consumption in lbs of fuel per hp per hour.
The trends in the data for the sea level test results is directly applicable to an auto diesel with similar intake temperatures and fueling.
