Old 04-21-2012, 12:31 AM   #57 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by tjts1 View Post
All the chicken or the egg arguments in the world are not going to resolve this. It would be relatively easy for me to test this idea with megasquirt.
Set the engine to a 2000 RPM fast idle in closed loop at 14.7 afr, engine hot.
Start recording a datalog
Let it idle unmolested for 30 sec
Spray water mist into the intake for 30 sec
Megalogviewer will record exact RPM, AFR (xx.xx), injector pulse width (x.xxx milliseconds) and wide band sensor correction (x.x% correction). If the water has any positive or negative effect, it will show as a change in RPM, pulse width or ego correction or most likely all 3.
I trust you're going to use pure water for this, and not a 50% mix of ethanol and water?
