Why mix it with anything?
I have a pressure vessel somewhere in the garage, fill it up with some distilled water, pressurize to 43psi with my air compressor, hook up a spare EFI injector at the other end and aim it into the open throttle body. The car has six 22# injectors so adding another one running the exact same PW would give a 6:1 fuel to water ratio.
easy
