Old 04-21-2012, 10:22 PM   #15 (permalink)
steffen707
Originally Posted by cbaber View Post
I know you can control Vtec engagement but the point of my post is why would you want to turn it on sooner or later than stock? Your not gaining anything out of it. And its not as easy as flipping a switch. Along with sending the proper signals you would need to tell the ECU to adjust fuel and timing to go along with the change in cam profile.
I think you're missing my point, if you were able to trick the ecu into thinking it should go into lean burn, it will adjust fuel and timing for you.
On the cam thing, I was thinking that if the engine were operating with all 4 valves as "normal" you might get better gas mileage,
And yes I have friends who can get 40mpg on their stock d16's Its not easy, but can be done. And if they're averaging 40mpg, then they are getting above 40mpg while cruising.
