Old 04-21-2012, 09:24 PM   #16 (permalink)
steffen707
Originally Posted by cbaber View Post
I guess the answer to your original question is that the VX and DX motors not in lean burn are essentially regular motors. They are not handicapped in any way when not using LB simply because of the unique head design and the other differences. You could easily achieve what a normal d16 would if you completely disabled LB on a VX/HX motor.
I'll try to find the link that explains why the vx is worse when not in lean burn.
