Originally Posted by eco_generator
So leading edge is vastly important if you are starting with a completely flat face...
That is my understanding.
Unlike most passenger cars and trucks today that early 60s semi tractor trailer example had high initial Cd (0.88) due to poor onset. I expect quantitative analysis (CFD, wind tunnel smoke) would show a lot of bow splash from initially stingy/small leading edge radii and turbulence from a large gap between the tractor and trailer. Cd reduced a lot by addressing those problem areas with modest treatments.
Originally Posted by aerohead
After initial gains the difference between modest and massive rounding of trailer front edges (shadowed by the tractor) provided marginal return.
Radical front redesign of the tractor was needed to further reduce the Cd to 0.46.
Much better ... and yet still worse than most passenger vehicles. because the large flat rear of the trailer acts like a drag chute. Hoerner showed this. Clean onset creates good attachment. Which also increases base drag. And thereby limits return on front investment. A boat tail is all the more important for a holistic solution and ultimate aero slippery.
Phil, thanks again for sharing all this research!
