Look into the 04-06 TJ/LJ mirrors. The housing is curved and more bulbous in shape than then the 97-02s flat slabs
Other things you may want to consider is a new front end, some way to bypass the upright front end.
Large air dam below to divert air past the steering linkage and the front diff
Extend the t-case skid plate back to the fuel tank with a cut out for the control arms and rear diff
Maybe consider lower it, or putting those wisker things in the fender wells to close the gap between the tires and the fender flares.
As a TJ owner, best of luck to you mate, its not going to be easy.
