Old 04-23-2012, 04:30 AM   #11 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
There pad type heaters. I have one on my oilpan to supplement the coolant heater, but I've seen users here with a heating pad on the engine block or transaxle. You could use a low power pad wrapped around the cat to slowly bring it partially up to temp, giving it a head start. If well insulated from the outside then maybe you might get it 60-80°C above ambient. Not sure if the pads are made to handle temperatures that high? I think it's doable, just need to get the parameters right.
Some of the pads are for 12V DC, so you could prewarm the cat 1-2 minutes before starting the engine, or keep it warm when coasting (SentraSE had a thread about that not too long ago).
PS: Why is this in the Unicorn Corral?
EDIT: You know, they make heating pads especially for cats. Meow cats
