Old 04-23-2012, 08:27 PM   #1 (permalink)
slowmover
90 day: 19.36 mpg (US)
New Diesel Record: 4.7-mpg!!
No typo. Up from 3.9-mpg. 20%.
That was Day Three of an oilfield truck driving job in a Model 367 Peterbilt 10-speed Eaton behind a Cummins ISX 485. TARE weight with trailer of @33,000-lbs. Delivering or removing up to 45k of rock dust with a pneumatic trailer (in a 4" i.d. hose this stuff weighs 75# per foot). The gearing is to get the load moving. Pulls like a freight train from any speed with 1,650TQ at 1,200-rpm. HP is 485 @ 1,800-rpm and governed at 2,100-rpm.
Truck is brand new (6k miles; break-in is past 100k miles), and it rides down the lease roads like a Cadillac. Governed at 65-mph (to 68 on cruise). Great seats. Air ride chassis, cab and seat. Plus trailer.
Another company, another job, but the same destination -- an oilfield well drilling site -- used a 9-mpg Freightliner (ex-WalMart). Different kind of load and trailer, so different TARE as well. Cheap seats, but air otherwise.
The new truck on the new job can travel the lease roads at twice the speed of the old truck. And doesn't pound the driver to death while doing it.
It took 1'15" the other night to travel 15-miles down a lease road near Encinal, Texas. Would have taken 2.5-hrs in the old truck. With the return trip included, the five hours to travel the same 30-miles versus about two-and-a-half in the new means money in the pocket for the driver (yours truly) since HOS (Hours-of-Service) limit how much we can work in a series of days (on a day-by-day basis).
So even though the older truck got better mpg and could run 74-mph guess which one is "more economical"? Rather, which one can really make money?
The truck that preserves hours and doesn't beat itself or the driver half to death. Five hours roundtrip after waiting or working 2, 3, or up to 9-hours at the site means at least one can get to a truckstop from some of these remote areas before running out of hours. Maybe even get the next load aboard before shutdown.
Now, not all lease roads are terrible. One can about fly through the million acre King Ranch (per their speed limits) on the little I have seen of it from the edges. (Note on the map that Driscoll, TX to Rivera, TX is 28-miles. And westward to Falfurrias another 22-miles. That's the N-S & E-W boundary of just one ranch section). Other ranches are not quite as large but may be harder to get into and to traverse. If I told you that I drove 10-miles into any ranch down here to the well site you could see why it wouldn't mean much, ha!
A rancher without mineral rights to his own land may not want road grading equipment at work any more than necessary; along with other reasons that "prevent" smooth access roads. One can spend more time on these unpaved lease roads traveling only a few miles compared to the highway miles back and forth to that entrance point.
These two truck firms operated on different levels of finance and philosophy. But . . . going down the highway seen from the level of the ordinary observer they're both still big trucks hauling oilfield tools, equipment and supplies. They still only deliver and pick up. Both are weight limited.
No run by either truck is more than about 150-miles from the home terminal. In both cases the material delivered is time-sensitive. One estimate of well drilling (not the fracking) is an average of $5-million in 28-days. Divide that by the hour to see what a delay costs. Dispatch is many hours ahead of arrival.
Idle time means, thus far, about a 21-mph average. Trucks don't get shut off. One gigantic GARDNER-DENVER pos-displace blower runs off that CUMMINS with a jackshaft at a 1,050-rpm engine speed when the truck is loading or unloading.
For Diesel_Dave: I read the PACCAR Owners Manual, the CUMMINS Manual and that of EATON. I was dismayed to see that cold start idle was to be until coolant reaches 130F and oil reaches 100F that the truck is not to be moved. ???? Well, the modern emissions package (variable vane turbo) can kick it up to those temps in only a few minutes. Awesome. The shop is running CHEVRON URSA 15W-40 and it looks like PM's are at 15k miles for this HD service.
Manifold pressure hasnt exceeded 30-psi and the truck comes up or down immediately (unlike older turbos). With gigantic external air cleaners and pre-cleaners that must be able to handle an inch of heavy dust and insects it has one great set of sounds as you move down the gears to make a 90-degree slow turn, and then come back up through the low side to rest in about First/High (6th) to "cruise" the lease road (12-mph). (I followed several other trucks in to a site the other evening and lost them in the dust cloud while in the "drag" position. Had to "navigate" [stay on the road] by watching the sides where the blade piles the dirt. In turn the other drivers had to warn me via CB of narrow cattle guards and to bypass old load limited bridges to one side or another. Have to figure out how to line up the 60' articulated rig while "at speed". In the dark. In the dust).
The 24.5 lug tires on the Drive axles appear to have above 1.25" tread depth (22.5 is the common size for on-road). LRR tires they ain't. No exhaust brake requirement, so to speak, but a slightly exotic manner of engaging and locking the two Drive axles if needed.
Late spring in the South Texas brush country also means I am picking up about 126 butterflies per hour en route. Have to install the radiator bug screen and can't seem to travel 100-miles without cleaning windshield glass. Otherwise some beautiful mornings en route as the caracara's battle turkey vultures over huge dead rattlesnakes on the remote roads.
6 days on and 2 off. I look forward to how "my" economy improves. I'm guessing it will be mainly about "progressive shifting" as truck idle time is pretty well set
And it's a rather funny image as I get back in my Cummins-powered pickup and have to remember another shift pattern and to use the clutch after a tiring day, ha! Rookie doesn't describe it. Ugly is more like it, but it's only about 7-miles to work each way.
So, remember: we'll drill till the day we die. The money is good if the hours are long. Guys arrive to find work here even without a place to live. However one thinks or feels (despite the major reasoning flaws of either a Daniel Yergin or a Bill McKibben) it's better to eat in the meantime. And fascinating to observe from any angle.
What I drive is just one of the little boys in these parts:
Representative Image:
Pneumatic Steel 575 c/f Trailer
Some of the trucks one see's are beyond mysterious. And some gigantic with equally gigantic loads. Not exactly with descriptive signage to them. When in doubt, just call it (some form of) a frac truck:
For another angle (and for someone owning an RV and wanting "easy money") look into gate guarding. Each well site has one. Here's a blog of one couple working with pics and descriptions. Retired folks and others wanting a few months, or a few years, of solid bankable money.
You won't none of you be surprised that throughout the "industry" that ex-military has significant representation.
The Following User Says Thank You to slowmover For This Useful Post:
t vago (04-23-2012)
