Old 04-23-2012, 11:53 PM   #9 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Originally Posted by baldlobo View Post
in theory a piece going back from the skid to the gas tank might be a good idea, but not all car manufactures skid the whole under carage of cars(mosty just the front; ie. the most dirty part of the car.)
Not many manufacturers actually give a ****, either. If you can, skin the whole thing. Also, with that approach angle you will definitely want an air dam. Otherwise your belly pan will compress air under the vehicle and create lift on the highway. If you go off roading and need the ground clearance, consider a removable dam.
