Headlight problem
Sorry i know it's not the right forum for this problem but I'm not on any other forums so i though someone here can help me.
My 99 civic driver side high beam doesn't work. Everything else works on both sides. I checked the voltage on all 3 connections on both sides and they are all fine. So right away i though i need a new bulb but it didn't solve the problem. I switched the bulbs from side to side and still the driver side high beam doesn't work but my voltmeter shows power to both low and high beam.
The only thing that hapens to the driver side light when i turn on the high beams is a very dim light comes on, not even strong enough to be the daytime running light.
