What do you mean check it? If i check ground to low beam it's showing battery voltage. If i put Ground to high beam it's showing battery voltage, so then the ground should be good, right?
The highbeam indicator on the instrument panel does not come on unless i disconect the plug from the bulb on the drivers side.
