Old 04-25-2012, 02:34 PM   #34 (permalink)
oil pan 4
For every degree (F or C it doesn't matter) you increase intake air temp your EGT see the same increase.
With DPF you need as much EGT as you can get to burn off the soot, I wouldn't be surprized if some diesels fired up their intake heater to help burn off the DPM.
My solution, ax the DPF. On larger diesels it can take up to 17 liters, 4+ gallons of fuel, $16 worth of fuel, to torch the DPM off the DPF.
This is a great deal for the government, they get over $2 in taxes for 0 miles driven on your part every time your DPF lights up.
