I might be installing my mpguino later today. I just finished the enclosure, I plan to add how I made it, with some pictures, later on. I was planning on wiring it to the main harnes at the ecu, I have read that some people have problems with readings when wiring at the ecu, even with the right wires. Then they re-wire in the engine bay and get the proper reading. Does anyone have an opinion on the best spot to splice in for vss/injector?
